1998 Nissan Pathfinder Problem!
MOMMADELL
  • 1998 NISSAN PATHFINDER
  • 6 CYL
  • 4WD
  • 160,000 MILES
The a/c only works when the fan is on "4" (of 1, 2, 3, 4). The fan blows just fine there, but nothing comes out (a/c or regular air) until it gets to "4".
Thanks!
Wednesday, June 25th, 2008 AT 12:14 PM
MERLIN2021
  • 17,250 POSTS
Test the blower resistor with an ohm meter your eadings should be...
1&2= .5-.6 ohms
1&3= 1.4-1.6
1&4= 2.5-2.8
Also test the connector for power with a voltmeter.
https://www.2carpros.com/forum/automotive_pictures/62217_Blower_Resistor_1.jpg
Wednesday, June 25th, 2008 AT 4:17 PM
MOMMADELL
  • 8 POSTS
I don't work on cars -- I just wanted some information for when I take it to a repair guy -- I don't want to be completely ignorant. I just need an idea of what it might be in case he says "You need a new XXXXXX for $$$$$!"
Thanks -
Wednesday, June 25th, 2008 AT 5:19 PM
MERLIN2021
  • 17,250 POSTS
OK but the resistor is an easy part to change.
Thursday, June 26th, 2008 AT 2:33 AM
MOMMADELL
  • 8 POSTS
So should I just say "I think it's the blower resistor"? One person I talked to said it could be one of the "relay switches" -- I don't know what that means...
I appreciate your advice.
Thursday, June 26th, 2008 AT 9:48 AM
MERLIN2021
  • 17,250 POSTS
What a customer should say, is "I need an estimate". Let them tell you what's wrong, if they son't get it right, they are on the hook, not you!
Thursday, June 26th, 2008 AT 1:10 PM
MOMMADELL
  • 8 POSTS
Thanks for the opening line -- that helps -- but I have no way of knowing then if they DO get it right. You think it's something called the blower resistor? If he says I need a new this and that, I won't know what to say.
Thanks -
Thursday, June 26th, 2008 AT 5:13 PM
MERLIN2021
  • 17,250 POSTS
All I can tell you from here is what the most common problem for your symtoms is, but it CAN be other things too. Say what I suggested.
Friday, June 27th, 2008 AT 4:35 PM
MOMMADELL
  • 8 POSTS
You were absolutely right -- it was the blower resistor -- charged me 70 for the part and 52 for labor. I appreciate your advice, and I will use this service again!
Wednesday, July 2nd, 2008 AT 12:04 AM
MERLIN2021
  • 17,250 POSTS
OK, nice to be cool eh? Feedback and points works for me!
Wednesday, July 2nd, 2008 AT 6:10 AM
MOMMADELL
  • 8 POSTS
I'm new to this service -- how do I leave feedback/points?
Wednesday, July 2nd, 2008 AT 9:51 AM
MERLIN2021
  • 17,250 POSTS
Under your name is a blue give feedback, click on that! And thanks!
Wednesday, July 2nd, 2008 AT 2:32 PM
MOMMADELL
  • 8 POSTS
I found what to click on - it's under your name, not mine - - but what is a point? Do I give 5 or 100? I have no idea what the scale is, and the popup window doesn't tell me. Thanks!
Wednesday, July 2nd, 2008 AT 7:21 PM
