Car stall and is hard to start at times?
130,000 MILES • 6 CYL • 4WD • AUTOMATIC
WMROCZKA
Car stall and is hard to start at times. Can start if I spray starting fluid in intake plenum. Replaced fuel pump, filter and relay. Still stalling. I am in the process of replacing fuel pressure regulator. Any other parts that would cause this problem?
Jul 6, 2010 at 12:20 AM
SQM
  • 6,383 POSTS
If you are able to start it with starting fluid, then it means that the engine is not getting fuel.
As you have a new fuel pump, it could be due to a clog in the fuel line or a bad fuel pressure regulator.
Check the fuel pressure using a pressure gauge. This vehicle should have 34-43 PSI of fuel pressure.
I have attached the fuel pressure regulator testing procedure below.
Dec 5, 2021 at 1:11 PM
