1997 Nissan Pathfinder Wiper Motor broke or is it linkage?
1997 NISSAN PATHFINDER
GERMAN3RDSS
1997 Nissan Pathfinder 6 cyl Four Wheel Drive Automatic
Ok I have a 1997 Nissan Pathfinder. Yesterday the wife attempted to use the wiper blades even though they were frozen to the window. When she started it, the motor made a "whirring" noise, like it was going to move them but nothing happened. After I freed them, I noticed that unless I "help" them along, the blades will not move.
Now if you try to work them, the first thing you notice is this whirring noise. Almost like something is trying to push them along. Now if you slightly nudge them then they "work". But when they get back to the original position, then the noise starts again until you nudge them. I am guess that the wiper motor somehow got fried but not all the way. ANyone have any ideas as to what might be happening? Thanks in advance.
I am thinking that perhaps it has something to do with the linkage. I am not sure BUT I do know that when the arms are nudged both arms go up. I am still thinking it might be the motor itself. I do not think that it would work at all if the motor itself was "busted". Still that whirring/grinding noise when I turn it on is the main thing.
1 hour ago
EDIT AGAIN
Ok another thing is this: If I make it so that the blades are not touching the windshield then they move AOK. SO that right there leads me to believe that it is not alinkage problem but rather a motor problem. But if I put them back in contact with the windshield, then I get the whirring/grinding noise which leads me to believe that the gears inside the motor are stripped but not totally. Does this make sense
Dec 29, 2009 at 11:35 PM
  • 31,937 POSTS
Hi there,
You will have to drop the motor out and check the spline for the regulator, i would say that has been stressed.
Mark (mhpautos)
Dec 29, 2009 at 11:54 PM
GERMAN3RDSS
So if the regulator (which I assume is in the motor itself) it would not make the wipers work. But if the pressure was off, sy in the upright position and NOT on the windshield then it might work as normal? Is that what I am understanding?
Dec 30, 2009 at 12:26 AM
  • 31,937 POSTS
The regulator is a set of linkages that interconnect the two wiper blades, the wiper motor drives this regulator, there regulator is attached to the motor by a splined shaft, if this pline is damaged, it can still drive with no load (wipers of screen) and slip with load (wipers on screen)
mark
Dec 30, 2009 at 12:30 AM
