knock sensor location
83,000 MILES • 6 CYL • 4WD • AUTOMATIC
TIKIBABY13
where is the knock sensor located at?
Apr 9, 2009 at 3:21 PM
  • 75,988 POSTS
The knock sensor is under the intake manifold, here is the instructions on how to change it out in the images below. Please let us know if you need anything else to get the problem fixed.
Apr 9, 2009 at 5:03 PM
ARMYDAD
Where is the knock sensor located on my vehicle?
May 23, 2019 at 10:41 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Hello, The knock sensor is located under the intake manifold between the cylinder heads. Here is the location
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_1439.jpg
Here is a better view (below) Please let us know if you need anything else to get the problem fixed. Cheers
WLIPS01
How do i locate and replace the knock sensor?
  • 75,988 POSTS
Knock Sensor On top rear of engine
https://images.2carpros.com/forum/automotive_pictures/12900_ks_27.jpg
WMROCZKA
1998 Nissan Pathfinder 6 cyl Four Wheel Drive Automatic
I am getting fault code for knock sensor failure.
The Haynes manual says it is located under intake plenum. I have removed it and cannot find any sensors under it or wires going to any sensors.
Where else could it be located?
May 23, 2019 at 10:42 AM (Merged)
  • 75,988 POSTS
Knock Sensor ECCS Component Parts Location
https://images.2carpros.com/forum/automotive_pictures/12900_k_3.gif
https://images.2carpros.com/forum/automotive_pictures/12900_k1_1.gif
Engine Control Component Part Location
https://images.2carpros.com/forum/automotive_pictures/12900_k2_1.jpg
https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
