1997 Nissan Pathfinder
153,877 MILES • 6 CYL • 4WD • AUTOMATIC
JONQ
OK i just got a new exhaust system installed.. and as soon asd i left the shop I started loosing power the engine bogs after about 15 minutes of drivng..and it also cuts off at red lights...im thinking it may be my cat may be clogged...any suggestions??
Apr 14, 2010 at 7:10 AM
  • 75,988 POSTS
Lack of acceleration,chugging,hesitating,bogging etc. could be caused by one of the following below.
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Apr 14, 2010 at 7:51 AM
