my 4 wheel drive does not work properly?
160,000 MILES • 6 CYL • 4WD • AUTOMATIC
LODOWIC
every time i have my tires rotated or put new tires on. my 4 wheel drive does not work properly it will not disengage unless i stop and back up and it seems to be in a lower gear i had this truck from new and it always had this problem every time i changed tires most of the time it would just return to normal but this last time it sts still not working properly.thank you
Dec 15, 2007 at 2:36 PM
2CARPRO JACK
  • 11,533 POSTS
That is how the auto-hubs unlock. They have been known to stick on occasion, causing a locked up front wheel.
Dec 16, 2007 at 11:36 PM
  • 55,647 POSTS
This happens when the transfer case actuator motor gets weak, here is the location of the motor and how to change it out.
Variations in tire size, even slight differences due to tread wear or mismatched replacements can create tension in the drivetrain, making it hard for the 4WD system to disengage properly.
Oct 30, 2024 at 11:12 AM
