1995 Nissan Pathfinder stalls
95PATHFINDER
  • 1995 NISSAN PATHFINDER
  • 6 CYL
  • 140,000 MILES
My 95 nissan pathfinder starts ok and idles fine. When the RPMs go up it stalls. It just looses power and shuts off, making it difficult to start shortly after.
I changed:
spark plugs
spark plug wires
distributer cap / rotor
fuel filter
I had the fuel injectors flushed
. And still nothing :(
Any suggestions?
Tuesday, July 22nd, 2008 AT 11:04 AM
SERVICE WRITER
  • 9,123 POSTS
Check for codes in the PCM.
Unplug the mass air flow sensor and see if it changes.
Disconnect throttle position sensor harness connector.
Make sure that resistance between terminals [b] and [c] changes when opening throttle valve manually.
If not, replace throttle position sensor.
Tuesday, July 22nd, 2008 AT 11:19 AM
