1995 Nissan Pathfinder headlights dont light
200,000 MILES • 6 CYL • 4WD • AUTOMATIC
ACE_05_PATH
both headlights stopped working. i have replaced one bulb in case both bulbs had burned out. fuses check good. park lights do come on. not sure what to check next. want to try everything before replacing the switch on the steering column.
thank you
Dec 6, 2008 at 4:42 AM
  • 75,988 POSTS
Test the combination switch which contaiins the lighting and dimmer switch, power comes from fuse no. 49/50 15amp then to the combo then to the L/R relays then to the lights.
The left/right lights has its on relay, the light is not coming on bcuz there's no power to the relays from the combo switch, this is your problem. Good Luck-HTH
Dec 6, 2008 at 5:41 AM
