1995 Nissan Pathfinder brake switch replacment
192,000 MILES • 4 CYL • 4WD • AUTOMATIC
MADDOG45
  • 6 POSTS
having a problem starting car andwas wondering if it could be the brake switch or something else
Feb 8, 2010 at 9:26 PM
BLUELIGHTNIN6
  • 16,542 POSTS
no, brake switch just operate the brake lights. is vehicle starting or not starting at all?
Feb 25, 2010 at 9:11 AM
MADDOG45
  • 6 POSTS
sometimes it does and sometimes it dosnt and i dont know why exactly
Feb 25, 2010 at 4:34 PM
MADDOG45
  • 6 POSTS
i also thought it might be the gear sifht switch because sometimes it hesitates when putting it in gear like drive,or reverse
Feb 25, 2010 at 4:37 PM
BLUELIGHTNIN6
  • 16,542 POSTS
try starting it in Neutral, if it starts then neutral safety switch is OK.
Feb 26, 2010 at 3:52 AM
MADDOG45
  • 6 POSTS
i tried that sometimes it starts and sometimes it dos'nt
Feb 26, 2010 at 4:19 AM
BLUELIGHTNIN6
  • 16,542 POSTS
when you say sometimes it doesnt start, what does it do exactly? does it just crank over and over or does it not crank at all? is the check engine light on when driving it?
Feb 26, 2010 at 4:31 AM
MADDOG45
  • 6 POSTS
sometimes it will not crank at all u turn the key and nothing happens like theres no power going to the starter motor and today for the first time the check engine light came on for like two minutes and then went off although the starting problem as stopped for the time being
Feb 26, 2010 at 9:15 AM
BLUELIGHTNIN6
  • 16,542 POSTS
ok if its not cranking at all sometimes then this could be a failing starter or a failling ignition switch. i suggest having the starter motor tested and if tests OK suspect faulty ignition switch or wiring to switch
Feb 26, 2010 at 9:17 AM
