1994 Nissan Pathfinder Replacing front disc brake piston O-
BRIANLCAIN
Brakes problem
1994 Nissan Pathfinder Four Wheel Drive Automatic 160000 miles
I'm having problems getting the boot to seat in the housing. Should I seat the boot in the housing before returning the piston or return the piston with the boot attached to it? I tried the latter and find the boot is not seating in the housing.
Many thanks,
Brian Cain
Jan 6, 2008 at 5:03 AM
SERVICE WRITER
  • 9,123 POSTS
The boot may not seat perfectly, but after the caliper is back on and you first press the pedal it will extend the piston back out relaxing the boot.
Jan 9, 2008 at 10:50 AM
