1994 Nissan Pathfinder Remote Keyless Entry
1994 NISSAN PATHFINDER
79,000 MILES • 6 CYL • 2WD • AUTOMATIC
BMAT1959
I have pushed the button on the RKE computer but it does not go into programming mode. It is supposed to give a series of beeps and them go into a beep every second or so. At that time i am supposed to press the button on the key fob to program it.
step 1: I insert the key and turn it on and then off.
Step 2: I press the button on the RKE computer and hold it down until i hear a series of beeps; i then release it and press the remote fob and the beeps will change to let me know it recognized the fob and programmed i t.
I do not get the series of beeps. it just goes straight into a beep every second or so.
Any suggestions?
Oct 6, 2008 at 3:20 PM
2CARPRO JACK
  • CAR REPAIR CONTRIBUTOR
  • 11,533 POSTS
When you hold the button down, does it give 4 tones, followed by a 5 tone burst?If not it isnt in programming mode.If it is in programming mode, it will let out single tones, these are the opportunity to program by pushing arm/disarm.Is the door closed when doing this? According to Mitchell any open pin switch could cause this. Nissan also had a problem with the pin switch under the hood
Oct 8, 2008 at 7:51 AM
