1994 Nissan Pathfinder a/c & heater blower
1994 NISSAN PATHFINDER
THEBLOS
Air Conditioning problem
1994 Nissan Pathfinder 6 cyl Two Wheel Drive Manual
the blower moter is new and its runs good but not much air is coming out of the vents, it is the same in all settings and a/c or heater, is there a filter on the inlet and if so were is it, or is there somthing blocking the inlet. All help well be grate THANK YOU JIM
Nov 16, 2008 at 3:57 PM
What make you replaced the blower motor-does the speed of the motor reacts when you move to higher blower speed?
Could be an air mix/blend/mode door problems to include vacuum/actuators
Nov 16, 2008 at 6:44 PM
THEBLOS
the blower motor was replaced due to it working when it wanted too, the new one works fine on all speeds but still not much air is moves out the vents, still locking for a ac filter or a blockage
Nov 30, 2008 at 5:46 AM
