1993 Nissan Pathfinder Starter problem?
150,000 MILES • 6 CYL • 4WD • AUTOMATIC
M CUTLIP
When I turn my key in the ignition, the car clicks and doesn't turn over. The built in security system also goes on even if the switch is turned off. We were able to get it jump started to get it home. Is this a battery problem or possibly a solenoid problem?
Mar 2, 2009 at 6:44 AM
  • 75,988 POSTS
. Is this a battery problem or possibly a solenoid problem? Could be both and other problems like the igniton switch, park and neutral switch and starter relay
Mar 2, 2009 at 8:08 AM
