1993 Nissan Pathfinder damper pulley
CJOBER
1993 Nissan Pathfinder 6 cyl Two Wheel Drive Manual
how to stop damper pulley from moving while braking crank bolt loose by hand
Mar 12, 2010 at 11:56 AM
OBXAUTOMEDIC
  • 3,711 POSTS
I have found it much easier to rent a 3/4" electric Impact Wrench to remove that bolt.
Doing it by hand will take just about forever. Believe me if you have a rental store check to see if they have one. Here were I live it's only $25 a day.
If cannot get tool you will need to remove starter and find a way to wedge something in the flywheel. However. to take the risk of braking the teeth on the flywheel doing it this way.
Mar 12, 2010 at 12:07 PM
