1992 Nissan Pathfinder Only heat
1992 NISSAN PATHFINDER
200,000 MILES • 6 CYL • 4WD • MANUAL
PJPOLITO
My AC compressor works, I've had that checked out by a technician, but only hot air is emitted from the vents, regardless of what I have the temperature is set too. I'm not sure if I have manual or electronic controls, the temperature has a sliding lever, but the AC and the top/bottom/defrost are all buttons. PLEASE any insight is HUGELY appreciated.
Apr 20, 2010 at 10:49 AM
Have the high and low pressure checked if okay could be air mix/blend/mode door problems, vacuum/actuator and the HVAC control module
Apr 20, 2010 at 7:58 PM
