1991 Nissan Pathfinder shifter lever
275,000 MILES • 6 CYL • 4WD • AUTOMATIC
CC1059
  • 12 POSTS
Hi, I recently replaced the starter on my 91 pathfinder; someway I must have caught something on the shifter linkage that goes into the transmission and pulled it out about an inch. I pushed it back in and went about finishing my starter instal. When I tried to start the car it would not start in park. I went to pull the shifter to N andit it would not click into the gears. In the approximate neutral position the truck started but was in drive and would not change out of that gear. Suspecting that I had slid the lever back in the wrong position I went back under the car pulled it out again to see if there was another position that it would fit. It did slide in easily with a slightly more forward angle but now when starting it is in reverse with the same shifter feel.
Sep 12, 2009 at 1:10 AM
  • 31,937 POSTS
HI there,
Thank you for the donation,
Undo the selector rod and manual select park on the transmission, don't touch the selector in the cabin, with the transmission in park check that the tail shaft is locked. now select park in the cabin, tighten up the selector at the box and check that the selector in the cabin indicates all gears selected,.
Mark (mhpautos)
Sep 12, 2009 at 2:47 PM
CC1059
  • 12 POSTS
hi thanks, did as you said but selector won't go through the gears. kind of a springy feel when trying to pull out of park. i did not try to start it but the tailshaft must have free'd when i pulled it out of park as the vehicle rocked a little on it's blocks.
any other thoughts?
craig
Sep 17, 2009 at 2:56 PM
CC1059
  • 12 POSTS
Hi Mark, thanks but still batting "0". Truck will start now in park, shifter lever will pull down but no matter how far stays in reverse. when I returned it back to park the engine still seems to be slightly loaded, meaning the engine idles as if in gear however the car does not move.
Craig[quote:38745b6542="mhpautos"]HI there,
Mark (mhpautos)[/quote:38745b6542]
Sep 19, 2009 at 4:03 AM
