1991 Nissan Pathfinder Control Module
1991 NISSAN PATHFINDER
MONKEY_80_91_69
Computer problem
1991 Nissan Pathfinder 6 cyl Four Wheel Drive Automatic
Where is the control module located on the 1991 Nissan Pathfinder?
Jan 11, 2010 at 4:01 AM
If you're talking about the ignition control module its also CALLED POWER TRANSISTOR Located on the R.H. side of the intake plenum, near the ignition coil. SEE BELOW
https://images.2carpros.com/forum/automotive_pictures/12900_POWER_RESISTOR_1.jpg
Jan 11, 2010 at 4:11 AM
