1989 Nissan Truck Hesitates at 2000 rpms
J_C_S_ONLINE
I have a 89 5 speed manual pickup that has 216k miles on it. It was running fine then one afternoon it started to choke and hesitate at around 2000 rpms. It does this no matter which gear you are in. I have replaced the fuel filter and the spark plugs. I have checked the hoses and don't seem to have any problems there. I am looking for ideas of what could be the problem.
Aug 2, 2007 at 12:32 AM
  • 75,988 POSTS
[quote:252af01cce="J_C_S_Online"]I have a 89 5 speed manual pickup that has 216k miles on it. It was running fine then one afternoon it started to choke and hesitate at around 2000 rpms. It does this no matter which gear you are in. I have replaced the fuel filter and the spark plugs. I have checked the hoses and don't seem to have any problems there. I am looking for ideas of what could be the problem.[/quote:252af01cce]
Check the fuel pressure w/a fuel pressure gauge then comeback with the results,we still got a long way to go. Did you check the fuse/s?
Aug 2, 2007 at 9:57 AM
