1989 Nissan Pathfinder FAILED AIR CARE ON IDLE TEST ONLY
1989 NISSAN PATHFINDER
260,000 MILES • 6 CYL • 4WD • MANUAL
DREDF
I have tried to get my car tested for air care but failed on idle test only and wondering what would be the cause of the problem.All other test passed with flying colors.
Dec 6, 2008 at 4:16 AM
Post the readings maybe I can help which one -HC/CO/O2/CO2/NOX
Dec 6, 2008 at 5:29 AM
DREDF
[quote:b7431ce35e="rasmataz"]I have tried to get my car tested for air care but failed on idle test only
Post the readings maybe I can help which one -HC/CO/O2/CO2/NOX[/quote:b7431ce35e]
My test results:
2008-03-17 13:49:38 261,000 Kilometers
Driving HC = 22 ppm Pass
Driving CO = 0.15 % Pass
Driving NOx = 47 ppm Pass
Idle HC = 143 ppm Pass
Idle CO = 3.73 % Fail
There must be some intermittent problem as over the years of testing .It has always been the Idle Test Failing and when it passes it's reading is very low from .026 to 1.49 readings
Any Ideas??
Dec 6, 2008 at 6:31 AM
Idle CO = 3.73 % Fail way too high
Have the coolant temperature and oxygen sensor checked out
Dec 6, 2008 at 6:44 AM
