Nissan Front Brake Squeak
NISSAN
TOMMYBOY2K
just recently i had to repair the rear brake light switch -which is located behind the brake paddle, and since then i have had an annoying sqeaking sound coming from the front brakes....it has been less then a year sense the car has had a new brake job...i just added brake fluid to see if that would stop the problem but it has not........sqeaking started last night.
HELP>
May 5, 2006 at 4:05 AM
LOSONE
  • 1,616 POSTS
Brake fluid won,t help the squeak unless you pour it on the noise. The front brakes have a wear indicator on the pads when they are worn they will make a nose. Inexpensive brakes pads last about a year.
May 6, 2006 at 9:00 AM
CBAILEYII
  • 26 POSTS
note---- when losone said pour it on the noise, he was very much kidding.
Pouring it on the noise may make the noise go away, but it will most likely make the car go away too.......like to the bone yard due to a major accident as a result of extreme loss of effective braking.
Check your pads, if they don't clear the wear indicator - Replace. I have noted this repair to run roughly 150 or so in most cases. However, it is really not very difficult in most cases with patience and the right DIY tools. Pads should run roughly 20-30
May 7, 2006 at 5:35 PM
Suggested Repair
Inspect the front brake pads for wear. If the pads have reached the wear indicator, replace them. Adding brake fluid will not stop pad squeal. Inexpensive pads often last about a year; replacement is commonly around $150, or a DIY job with pads roughly $20-30.
Conversation Summary
A Nissan owner reports front brake squeaking that started after repairing the rear brake light switch. A brake job was done less than a year earlier, and adding brake fluid did not help. Experts say fluid will not stop the noise and that worn pads with wear indicators commonly squeak, especially inexpensive pads. They recommend checking pad thickness and replacing the pads if they have reached the wear indicator.
