1986 Nissan Stanza Won't Crank
NISSAN
POLICEMAN
purchased 1986 nissan stanza with 175,000 miles on it. The vehicle had been sitting for about 1 year. Replaced the fuel, the battery, and cleaned the spark plugs. The car almost turns over then starts clicking as if the battery is dying. However the lights come on brightly ect.
What do you suggest....
May 16, 2007 at 3:57 PM
  • 75,988 POSTS
[quote:416cc63518="policeman"]purchased 1986 nissan stanza with 175,000 miles on it. The vehicle had been sitting for about 1 year. Replaced the fuel, the battery, and cleaned the spark plugs. The car almost turns over then starts clicking as if the battery is dying. However the lights come on brightly ect.
What do you suggest....[/quote:416cc63518]
Remove all the sparkplugs spray some WD40 on ea. port-try and crank engine over without the plugs.
Cranking problems continue with a known good battery and connections clean/tight. Then its time to check the starter relay and starter. Also a voltage drop test on each cable pos. and neg.
Remember 1yr is a long time the engine is tight-similar to a hydrolock but less-
Good Luck
May 16, 2007 at 7:29 PM
Suggested Repair
Remove the spark plugs, spray WD-40 into each port, and try cranking with the plugs out to free a tight engine after long storage. If it still only clicks with a known-good battery and clean, tight connections, test the starter relay and starter and perform a voltage-drop test on the positive and negative cables.
Conversation Summary
A 1986 Nissan Stanza with 175,000 miles sat for about a year and will not start. The owner replaced the fuel and battery and cleaned the spark plugs; it almost turns over, then clicks as if the battery is dying, although the lights stay bright. The expert advised removing the plugs, spraying WD-40 into the ports, and cranking without plugs because the engine may be tight. If cranking problems continue, check the starter relay and starter and do a voltage-drop test on both battery cables.
