Nissan Micra Heat Shield
NISSAN
STUARTGOOD24
Hi, I am wandering if anyone has had this problem before, the heat shield on my nissan micra 1997 is rattling and i was wandering what the best solution would be? can i simply just pull it off? can i simply tighten it? if so what should i be tightening and also looking for? not 100% on car repair thats all! any help would be gratefully received.
Thanks in advance
Dec 16, 2006 at 5:23 AM
CARUNDELL
  • 602 POSTS
[quote:2277b0a710="stuartgood24"]Hi, I am wandering if anyone has had this problem before, the heat shield on my nissan micra 1997 is rattling and i was wandering what the best solution would be? can i simply just pull it off? can i simply tighten it? if so what should i be tightening and also looking for? not 100% on car repair thats all! any help would be gratefully received.
Thanks in advance[/quote:2277b0a710]
Hey Stuart,
Technically it should stay on. If you can tighten it Great!. If its all rotted/rusty where it bolts then get an extra large hose clamp or put 2 or 3 together, rap it around the heatshield and tighten it that way. This will eliminate the rattle.
Chris
Dec 16, 2006 at 8:13 PM
STUARTGOOD24
hi thanks chris for replying,
what should i be looking for as im not sure whats really what under the bonnet!
something i should probably know a lot more about i feel!
thanks
Dec 17, 2006 at 5:29 AM
