nissan bluebird intermittent engine "off"
NISSAN
DIRK_GARNETT_06
  • 5 POSTS
hi......I have a 1995 Nissan Bluebird having a CA20 engine(EFI). I sometimes experience engine "off"/car stalled specially during cold weather when I decelerate abruptly(e.g., sudden brake engagement coming from high RPM or speed). I can re-start my car after a while and can run, but it's annoying to anticipate such phenomena. Please help....
Oct 10, 2007 at 5:42 PM
  • 75,988 POSTS
Find the EGR and open it up and look for carbon, and make sure its getting vacuum at the right time. Also inspect and test the throttle position sensor and throttle switch. To include the idle air adjusting unit/airflow meter.
Oct 10, 2007 at 10:49 PM
DIRK_GARNETT_06
  • 5 POSTS
[quote:a47384a6cf="rasmataz"]Find the EGR and open it up and look for carbon, and make sure its getting vacuum at the right time. Also inspect and test the throttle position sensor and throttle switch. To include the idle air adjusting unit/airflow meter.[/quote:a47384a6cf]
Hello.....above quoted message is the answer for my previous query. Can you please help to locate where my EGR, throttle position sensor, throttle switch are? My car is a 1995 Nissan Bluebird with CA20(EFI) engine, manual transmission. I'll really appreciate if you can send/post any helpful illustration/image. Thank you very much!
Oct 16, 2007 at 4:04 PM
