1997 Nissan Quest No-Start Knock Sensor
NISSAN
KEVAN TURNER
I have a 1997 villager/quest 140000 mi. It stopped dead in the road while driving and won't start. The OBD 11 flashes 3 long 4 short indicating a problem with the knock sensor. I have voltage at the conector but no change in reading when engine is hit with a hammer. Is it possible for the knock sensor to disable the engine if it goes bad. I understand that it controls the timing. when cranking the engine sounds like it's trying to run for a couple turnes after letting of the starter. Should I be looking at the timing belt? The engine has spark and spraying cleaner into the intake has no effect. I'm trying to find an easy answer before I take the top off the engine to replace the sensor. Thank you in advance for your attention to my problem.
May 9, 2007 at 4:57 PM
  • 75,988 POSTS
Sir,
The knock sensor will not disable your vehicle its purpose is to retard the ignition timing when it senses a detonation/spark knock/pinging
You stated putting cleaner into the intake has no effect and also has spark. If compression and fuel were okay it should fire and start.
If its a distributor system-unclip/unscrew the D/Cap while cranking the engine is the rotor spinning? If not investigate the T belt/chain.
Rotor spinning could be a valve and ignition timing problem that's preventing it from starting up.
Check the fuel pressure and comeback.
May 9, 2007 at 5:26 PM
Suggested Repair
A failed knock sensor will not disable the engine; it only retards timing when knock is detected. With spark present and intake cleaner having no effect, confirm the distributor rotor spins while cranking. If it does not, inspect the timing belt or chain. If it does, check valve and ignition timing and test fuel pressure.
Conversation Summary
The owner of a 1997 Villager/Quest with about 140,000 miles reports the engine died while driving and will not restart. An OBD code points to the knock sensor, which has voltage but no response when tapped, and the owner asks whether a bad sensor can disable the engine or whether the timing belt should be checked. Spark is present and spraying cleaner into the intake has no effect. The expert explains that the knock sensor only retards timing and will not shut the engine down, and advises checking whether the distributor rotor spins while cranking, investigating the timing belt or chain if it does not, and checking timing and fuel pressure if it does.
