fuel injectors
NISSAN
NCSWEETGIRL
1997 Nissan Hardbody 4 wheel drive extened cab 189.666
Just replaced the engine. motor will turn over, but not crank, fuel injectors isnt getting any fuel? Any suggestions ? Or maybe the computer is bad? Please Help
Thanks
Apr 25, 2007 at 1:43 PM
I assumed there's spark. No fuel could be a fuel pump relay,pump-fuel pressure regulator not maintaining the pressure, last the quad driver in the computer.
Apr 25, 2007 at 7:08 PM
NCSWEETGIRL
[quote:a06b21f561="rasmataz"]I assumed there's spark. No fuel could be a fuel pump relay,pump-fuel pressure regulator not maintaining the pressure, last the quad driver in the computer.[/quote:a06b21f561]
how do you check the quad driver in the computer? Thanks for replying. :D
Apr 25, 2007 at 9:59 PM
[quote:6c031cac92="ncsweetgirl"][quote:6c031cac92="rasmataz"]I assumed there's spark. No fuel could be a fuel pump relay,pump-fuel pressure regulator not maintaining the pressure, last the quad driver in the computer.[/quote:6c031cac92]
how do you check the quad driver in the computer? Thanks for replying. :D[/quote:6c031cac92]
Crank the engine over the injector should be clicking/buzzing meaning its being pulsed by the driver in the computer.
Apr 25, 2007 at 10:26 PM
NCSWEETGIRL
[quote:451a87a2cf="rasmataz"][quote:451a87a2cf="ncsweetgirl"][quote:451a87a2cf="rasmataz"]I assumed there's spark. No fuel could be a fuel pump relay,pump-fuel pressure regulator not maintaining the pressure, last the quad driver in the computer.[/quote:451a87a2cf]
how do you check the quad driver in the computer? Thanks for replying. :D[/quote:451a87a2cf]
Crank the engine over the injector should be clicking/buzzing meaning its being pulsed by the driver in the computer.[/quote:451a87a2cf]
There is a clicking sound. So, that means????
Apr 26, 2007 at 12:06 AM
[quote:6f39404349="ncsweetgirl"][quote:6f39404349="rasmataz"][quote:6f39404349="ncsweetgirl"][quote:6f39404349="rasmataz"]I assumed there's spark. No fuel could be a fuel pump relay,pump-fuel pressure regulator not maintaining the pressure, last the quad driver in the computer.[/quote:6f39404349]
how do you check the quad driver in the computer? Thanks for replying. :D[/quote:6f39404349]
Crank the engine over the injector should be clicking/buzzing meaning its being pulsed by the driver in the computer.[/quote:6f39404349]
There is a clicking sound. So, that means????[/quote:6f39404349]
It means the ECM is pulsing the injectors-Now go and do a fuel pressure check
Apr 26, 2007 at 1:18 AM
NCSWEETGIRL
[quote:bb509df06d="rasmataz"][quote:bb509df06d="ncsweetgirl"][quote:bb509df06d="rasmataz"][quote:bb509df06d="ncsweetgirl"][quote:bb509df06d="rasmataz"]I assumed there's spark. No fuel could be a fuel pump relay,pump-fuel pressure regulator not maintaining the pressure, last the quad driver in the computer.[/quote:bb509df06d]
how do you check the quad driver in the computer? Thanks for replying. :D[/quote:bb509df06d]
Crank the engine over the injector should be clicking/buzzing meaning its being pulsed by the driver in the computer.[/quote:bb509df06d]
There is a clicking sound. So, that means????[/quote:bb509df06d]
It means the ECM is pulsing the injectors-Now go and do a fuel pressure check[/quote:bb509df06d]
Ok, talked to my son, he said that the fuel and pressure is getting to the injectors, but its not firing. Sorry, to be so much trouble.
Apr 26, 2007 at 1:22 AM
