1988 nissan pulsar nx se 1.6,156,000 mi,fuel filter problem
1988 NISSAN
WALTHUR
bought car, drove two weeks, engine light comes on and dies. cool off restart and drive. interrmittant problem becomes permanant. fuel filter replaced, drive two days, repeat! on third fuel filter.
Jan 28, 2007 at 8:49 AM
Check the fuel pressure-sounds like the pump is failing.
Jan 28, 2007 at 8:53 AM
Crap can be the problem-now you need to get in there maybe thru the backseat to access it-
Check the fuel pressure and also the fuel pump relay. When it goes dead-immediately look for spark and fuel this will give you a direction where to go.
HTH
Jan 28, 2007 at 9:11 AM
WALTHUR
has spark, died on me last night. below zero temps. replaced fuel filter this morning. ran til completely warmed up, no problem yet. idles slow but dealer adjusted TPS. now idles about 500 RPM. fuel pump only runs 3 to 4 seconds now but 8+ w/bad filter.
HEET and additives in tank. full tank of gas.
Jan 28, 2007 at 9:23 AM
