1992 Nissan Stanza Cooling Fans Shut Off
NISSAN
RNSONOMA
I have a 92 Stanza XE, 100k miles, 2.4liter and noticed it was getting hot today. Sure enough it needed water, but I noticed the fans werent spinning. While filling the radiator they kicked in then shut off again while the engine was running. Yet the temp returned to normal. Any ideas on why the fans would shut off while the engine was running?
Thanks
Jun 12, 2007 at 12:04 PM
BACKYARDMECHANIC
  • 337 POSTS
The fans are controled by a thermostat that causes the fan to turn on and off. A thermostat is a switch that is effected by temperature change. When the temperature rises the thermostat will close, causing the fan to turn on. The fan will run untill the engine temperature is lowered enough for the themostat to open and this will then cause the fan to shut off. This cycle of on off happens continuously as long as the car is running.
Jun 12, 2007 at 12:31 PM
Suggested Repair
No repair is indicated if the temperature returns to normal. The cooling fans are controlled by a temperature thermostat that turns them on when the engine is hot and off once it cools enough. This on-off cycle continues while the engine is running.
Conversation Summary
The owner of a 1992 Nissan Stanza XE with a 2.4L engine noticed it running hot and low on coolant, and the radiator fans were not spinning. The fans came on while the radiator was being filled, then shut off with the engine still running, and the temperature returned to normal. The expert explained that a temperature-sensitive thermostat switches the fans on when hot and off once the engine cools, so this cycling is normal while the car is running.
