1988 Nissan Colt Low Idle Stalls in Gear
NISSAN
COLTEN
Hey, i have Nissan Colt, 1988, 1.8L V4,174000 miles on it.
We do not know if it had a throttle body or not, but it idle's really low. so we put in just a piece of wood to keep up the idling, but as soon as we kick it into any driving gear the engine drops in its RPM's and stalls. What can we do?
May 25, 2007 at 3:38 PM
  • 75,988 POSTS
[quote:7316d0bf01="Colten"]Hey, i have Nissan Colt, 1988, 1.8L V4,174000 miles on it.
We do not know if it had a throttle body or not, but it idle's really low. so we put in just a piece of wood to keep up the idling, but as soon as we kick it into any driving gear the engine drops in its RPM's and stalls. What can we do?[/quote:7316d0bf01]
Check the ignition timing before you do below
Disconnect the throttle position sensor-find the idle air control valve and adjust it till you hit 750rpm.
May 25, 2007 at 5:58 PM
KIN CHAN
  • 453 POSTS
if it is a tbi ...the MAF is build within.use a volt meter...set it up max & min...catch it while it fall off....seen quite a bit of those problem...lets not 4get that vac leak is #1 idle stall offender
Jun 10, 2007 at 10:54 AM
Suggested Repair
Check ignition timing first. Disconnect the throttle position sensor, locate the idle air control valve, and adjust idle to about 750 rpm. Also check for vacuum leaks and, if the engine is throttle-body injected, test the built-in MAF signal with a voltmeter while idle drops.
Conversation Summary
The owner of a 1988 Nissan Colt reported very low idle and used a piece of wood to hold the throttle open, but the engine still dropped rpm and stalled when shifted into gear. Advice was to check ignition timing, disconnect the throttle position sensor, adjust the idle air control valve to about 750 rpm, and investigate vacuum leaks or a dropping MAF signal if the engine uses throttle-body injection.
