HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Nissan
Other
Engine
Crankshaft Pulley
SPONSORED LINKS
1995 Other Nissan Models Crank pulley Bolt
DMSCAR
MEMBER
1995 NISSAN
6 CYL
FWD
AUTOMATIC
120,000 MILES
What is the socket size for the crankshaft pulley bolt (front) on a 1995 Nissan Quest GXE
Friday, December 12th, 2008 AT 10:49 AM
MECHANIC
Its either a 17MM or 19MM
SPONSORED LINKS
Friday, December 12th, 2008 AT 12:05 PM
DMSCAR
MEMBER
Incase anyone needs to know. Use a 27MM to pull off your front crankshaft pulley bolt, that size fits.
Monday, December 29th, 2008 AT 12:18 PM
Please
login
or
register
to post a reply.
Related Crankshaft Pulley Content
1995 Nissan Vacuum Hose Routing
Need A Vacuum Hose Routing Sheet For 1995 Nissan Quest Gxe (engine Compartment)
Asked by
dmscar
1 ANSWER
1995
NISSAN OTHER
1995 Nissan Nissan Skyline R33 O2 Sensor Help
Electrical Problem 1995 Other Nissan Models 4 Cyl Wheel Drive Type Unknown Manual 140000 Miles 95 Nissan Skyline R33 The O2 Sensor...
Asked by
NIs_Skyline_r33
1995
NISSAN OTHER
1988 Nissan D21 4x4 2.4l, 96,000 Miles, Oil Pump
I Found An Oil Leak On The Oil Pump, So I Took It Off And Used Gasket Maker. The Problem Is That Now It Won't Start. Is There A Certain Way...
Asked by
bet1974
1988
NISSAN OTHER
2000 Nissan Oil Pan
2000 Other Nissan Models Two Wheel Drive 73,000 Miles How Do Yo Open The Oil Pan Of Nissan Patrol 2000 Model?
Asked by
kingkong_002
1 ANSWER
2000
NISSAN OTHER
Camshaft Brackets Positioning
Hello I Have Removed The Camshaft Brackets, And Now I Do Not Remember Where To Put Them. Some Camshaft Brackets Are With Numbers And Some...
Asked by
xhoin
1 IMAGE
2008
NISSAN OTHER
VIEW MORE
SPONSORED LINKS
Serpentine Belt Replacement
Serpentine Belt Replacement Dodge
Online car repair manuals
