95 nissan p/u won't run
1995 NISSAN
DPM
I have a 95 nissan p/u with 54,000 miles. The other day I was driving and all of a suddent the engin quit. I tries to re-start, but all that happens is the engine rough idles and when you give it gas it stalls. I have dis connected the fuel filter and turned on the trucck. Gas pumps out of the filter. I checked the air intale & filter for clogs. What should I try next??
Thanks
May 21, 2007 at 3:36 AM
[quote:9b84473b32="dpm"]I have a 95 nissan p/u with 54,000 miles. The other day I was driving and all of a suddent the engin quit. I tries to re-start, but all that happens is the engine rough idles and when you give it gas it stalls. I have dis connected the fuel filter and turned on the trucck. Gas pumps out of the filter. I checked the air intale & filter for clogs. What should I try next??
Thanks[/quote:9b84473b32]
Look for spark, no spark troubleshoot the ignition system- spark okay-look for fuel and check the fuel pressure then comeback before we go somewhere else.
May 21, 2007 at 11:22 PM
