2007 Other Nissan Models Non ABS to ABS Conversion
2007 NISSAN
6,500 MILES • 4 CYL • 2WD • AUTOMATIC
HICOUNTRY
MEMBER
1 POST
I have a 2007 Nissan Versa with standard type brake system. Is it possible to convert the brake system to an ABS braking system.
Dec 29, 2007 at 9:12 AM
✓Experienced Mechanic
Hi there,
I feel that you would be able to do the conversion, but the cost would be astronomical as there is a huge difference in the two systems, things to consider would be brake rotors, sensors, suspension arms may differ if that is wher the sensors mount, ABS control unit, electrical loom, computer (ECU). i feel the cost would out weight the advantage.
