2006 Other Nissan Models Right side rear disc not rotating f
2006 NISSAN
KENRICK
Brakes problem
2006 Other Nissan Models 6 cyl Front Wheel Drive Automatic
Changed the rear disc pads. The passenger side rear hub is next to impossible to move - it will not rotate with or without pads installed. I have never replaced pads on a vehicle with ABS. Is this normal? Is it an ABS issue?
Nov 4, 2008 at 2:15 AM
ZACKMAN
  • 4,202 POSTS
Did you twist the piston all the way so it goes back into the caliper? You can't twist it by hand, there is a tool that sells for $10 to help you with the work.
Nov 4, 2008 at 11:33 AM
