2005 Other Nissan Models Noise in the Engine
2005 NISSAN
12,000 MILES • 6 CYL • FWD • AUTOMATIC
RAJ NAIR
Issue # 1) The car when accelerator is given when the RPM needle reached 2 in the dial produces a roaring sound and the pick up gets slightly slow unless the pedal is pressed with more strength. There is a dent in the silencer muffler also.
Issue # 2) The Service Engine light is on . The light remains on for a couple of weeks and goes off for 2-3days and come back to on position again.
Seek your advice for the above listed issues to enable me to get the car repaired at a Nissan service center in UAE. (They are reluctant to service this car as it is an US Spec car though it is made in Japan)
Oct 21, 2008 at 7:05 PM
2CARPRO JACK
  • 11,533 POSTS
need to start with a scan of the pcm to see why the check engine light is on.This may lead to the cure for the engine noise.Get back to me with the codes.
Oct 27, 2008 at 9:52 AM
