2004 Nissan Murano won't go into Reverse or Park
2004 NISSAN
AFCERIK
1. 2004 Nissan Murano SL AWD
2. 30519 miles
3. Automatic Transmission
4. Strange sounds or smells (if any): NONE
5. Fluid leaks (if any): NONE
6. Past repair history (if applicable): NONE
After driving from cold engine for about 10 minutes, while in Drive and stopped, I can't get the gear shift into Reverse or Park. The gear shift only moves between N, D-S, and L.
I let the car sit over night, but the problem persists.
This happened once before several weeks ago, but it apparently fixed itself after 20 minutes or so.
thanks!
Oct 25, 2007 at 5:10 AM
MERLIN2021
  • 17,250 POSTS
I think you got luck once before! I think you need to adjust the shift cable, here's a diagram, and instuctions...
https://images.2carpros.com/forum/automotive_pictures/62217_Muranoshift1_copy_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_Muranoshift_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_30961_mitchell_2_64.jpg
Oct 25, 2007 at 6:08 AM
