2000 Quest - Replacing Axles
2000 NISSAN
ENZO_THE_BAKER
2000 Nissan Quest GXE, 104K, 3.3L V6.
CV joints on both front axles are shot. Anybody know of a procedure for removing and replacing the axles on this vehicle?
Nov 26, 2007 at 2:22 AM
2CARPRO JACK
  • 11,533 POSTS
Need to lift and support front of vehicle. Remove both wheels and axle nuts, seperate lower ball joints from steering knuckle.Pull axle out of spindle (steering knuckle), using a pry bar, pop axles out of trans and remove from vehicle.
https://www.2carpros.com/articles/mitchell1eautorepair-car-repair-manuals
Will have more detailed instructions
Nov 26, 2007 at 5:04 AM
ENZO_THE_BAKER
Thanks Jack! Any tricks to getting the new axles in, or is it pretty straightforward? Also, what are the torque settings for the axle and ball joint nuts?
Nov 27, 2007 at 1:12 AM
2CARPRO JACK
  • 11,533 POSTS
I usually positin the open end of the retaining clip down.
Ball joint stud nut- 52-63 ft lbs
Wheel bearing lock nut- 174-231 ft lbs
Nov 27, 2007 at 3:54 AM
