2000 Other Nissan Models Fuel problem
2000 NISSAN
100,155 MILES • 4 CYL • 4WD • AUTOMATIC
MOHAMMED OWEZ
Its a Nissan Mistral, TD27BKCO6752A. when the vehicle is in drive or in reverse and in slope position the vehicle idle becomes very unstable and stops. you need to pump the primary pump then re start. have directed the fuel hose without using the primary pump and fuel filter the vehcile still stops.
Feb 14, 2010 at 1:59 PM
  • 110,246 POSTS
Has the check engine light come on? Have you checked for vacuum leaks? Fuel pressure?
Apr 22, 2010 at 3:49 AM
