1999 Other Nissan Models diesel wont start
1999 NISSAN
95,000 MILES • 4 CYL • 2WD • MANUAL
KAMMY6000
hi, i have a nissan primera 2.0 diesel turbo after having to auto electricians out and 2 mechanics at my door its still a mystery why it wont start, the ecu showed report one fault,the fuel temp control is not perfect but still works! the car stopped on the motorway doing 70mph and since hasn't started again ?
1.starter turning yes
2.fuel line line ok yes
3.fuel present yes
4.battery full yes
5.tried pumping fuel through just incase air spot yes
6.glow plug check yes
7.air filter change yes
any help would be appreciated thanx
Jun 6, 2008 at 10:39 AM
LADIDEL
hallo I´m from Germany and my nissan td 2,0 runs 285,000.I had problems to start from time to tome, then didn´t sart any more after running. Changed crank shaft sensor - and solved the problem. Now new troubles ahead with other sensors. Good luck
and check fault codes by yourself with MIL
ladidel
Jul 21, 2008 at 8:41 AM
