Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Nissan
Other
Engine
Symptoms
Overheat
1998 Other Nissan Models Overheating
1998 NISSAN
180,000 MILES • 4 CYL • FWD • MANUAL
BOILINGINAZ
MEMBER
1 POST
I have replaced my radiator, fan and thermostat and still the car overheats with the overflow tank bubbling. What else could the problem be?????
Jun 12, 2008 at 1:32 PM
KHLOW2008
Experienced Mechanic
Hi BoilinginAZ,
Check radiator cap pressure.
Did you bleed the system of air? Too much air trapped in system would cause overheating.
Fans are new, but are they working and at the appropriate temp reading?
A faulty or weak water pump would have reduced water volume moving through the radiators. So does clogged passages or kinked hoses.
Last and costliest of all is a blown head gasket.
Jun 13, 2008 at 3:02 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine overheating
