1998 Other Nissan Models heater resistor/heated rear window
1998 NISSAN
83,000 MILES • 4 CYL • 2WD • MANUAL
MARTHIDES
Hi
I have a 1998 Micra, the blower only works on full. I have been told it may be the resistor that needs replacing. Where is the resistor located?
The heated rear window switch no longer works, I have changed the fuse and it blew straght away. Could it be the switch that needs replacing?
I would be grateful for any feedback it would be much appreciated. Many thanks Martin.
Feb 8, 2008 at 1:50 PM
DAVE H
  • 13,384 POSTS
the resistor is located on the heater blower unit and check the wiring for the rear defrost !
May 3, 2009 at 6:33 AM
