abs warning light is on as abs sensor is broken where is it located on the wheel
Sep 23, 2008 at 1:48 PM
ZACKMAN
✓ASE Certified Mechanic
As your model wasn't defined, I can only give you general description. Depending on model, the front sensor is usually on the steering knuckle close to the CV axle sensor ring. The rear sensor is usually attached to the axle hub.
Sep 25, 2008 at 11:08 AM
