1996 Other Nissan Models Window motor
1996 NISSAN
180,000 MILES • 4 CYL • 2WD • MANUAL
PDROBINSON
My drivers side power window goes down but will not go up. The motor is running but the cable is not moving. If I take the door apart and lift up on the bottom of the window as I hold the button it will go up. Do you think the motor is bad or might I have another problem? Thanks
May 9, 2008 at 11:14 AM
MASTERTECHTIM
  • 4,750 POSTS
your prob lem is a b ad window regulator. thats the part the motor is bolted to. very common.
May 9, 2008 at 11:23 AM
