1996 Other Nissan Models Oil Leaks
1996 NISSAN
197,084 MILES • 4 CYL • FWD • AUTOMATIC
MARKB615
My 96 Nissan 200sx has a oil leak. And I am getting oil in my air filter.
Jun 12, 2008 at 12:11 AM
  • 31,937 POSTS
Hi there,
If you are getting oil in your air cleaner, this is a sign of a problem with the engine, excessive crank case pressure will be carrying oil into the air cleaner via the PCV. now you may just have a faulty PCV so may be replace it first, but if you run the engine and remove the oil filler cap and there is excessive pressure , you have a ring problem.
Mark (mhpautos)
Jun 12, 2008 at 12:20 AM
