1996 Other Nissan Models Brake Rotor and Tire Rm are very ho
1996 NISSAN
125,255 MILES • 6 CYL • FWD • AUTOMATIC
KENKOIS
Aloha,
Just changed my front disc brake pads on my 1996 Nissan Quest Van. While driving about 2 miles, the two front rims are very hot. You can touch the rims for a maximum of 3 seconds before it gets unbearable. What could be the problem. The car drives well and the brakes work. I did not bleed the brake system.
Oct 10, 2008 at 11:13 AM
BLACKOP555
  • 10,386 POSTS
did you grease up the proper parts of the brake system when puttin on new pads? with vehcile jacked up are wheels hard to turn by hand?
Oct 10, 2008 at 12:35 PM
KENKOIS
no. did not grease any brake parts? which parts should i grease and where are they. also, the front wheels were hard to turn.
Oct 11, 2008 at 5:24 PM
BLACKOP555
  • 10,386 POSTS
grease where the brake pads slide on the calipers, on the caliper bolts/slide rails basically any part that moves on the bracke shoes and caliper.
if this dont help try breaking open the bleeder valves does that loosen the wheels now?
Oct 12, 2008 at 1:24 AM
