1995 Other Nissan Models WONT START
VALPEE
  • 1995 NISSAN
Engine Performance problem
1995 Other Nissan Models 6 cyl Automatic 165505 miles
HAVE NISSAN MAXIMA 1995 TRIED OF GUESSING GAMES SINGAL MOM NOT ALOT OF MONEY JUST NEED HELP! CAR WONT START SEEMS LIKE IT WANTS TO TURN OVER BUT WONT SEEMS LIKE ITS NOT GET FIRE OR NO SPARK.
Friday, March 26th, 2010 AT 5:49 PM
Do below to determine if its fuel or spark problem and get back with some results
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Friday, March 26th, 2010 AT 5:57 PM
