1995 Other Nissan Models knock and egr sensor code
1995 NISSAN
114,500 MILES • 6 CYL • 2WD • AUTOMATIC
COMANDO
I have 1995 Nissan Quest van and the van had water leaks under the intake manifold on the top of engine from heater bypass hoses so I replased the hoses and fixed this problem by taking out intake manifold befor this I didnt have any check engine light, but after i did this job my check engine light poped up the code was EGR and KNOCK sensor so I took intake one more time and replaced KNOCK sensor with new one but i still have the code the check engine light what that could be?
thanks
Oct 12, 2008 at 1:59 PM
LEGITIMATE007
  • 5,121 POSTS
make sure that you dont have any pinched hoses/vacuum under neath the manifold or anywhere around it. also look for disconnected hoses
Oct 12, 2008 at 2:12 PM
LEGITIMATE007
  • 5,121 POSTS
if that doesnt correct the problem , then take it to autozone for a free scan and bring the trouble code back to me. and we will take it from there
Oct 12, 2008 at 2:14 PM
