I, also, just had the starter replaced on December 31st of last year (this is the one that was initially transferred into the new engine), May 16th of this year (and then again on May 17th because the first two they put in were defective).
A couple of days ago the engine started making an almost chirping sound while I'm driving (usually starting about 30 mph and continuing until I come to a stop). Now today, on top of the noises, I made a 5 minute stop, turned the car off and had a hard time restarting it. It turned over but took a while to catch. The second stop I made was for about the same amount of time with the same result - only it took a *little* longer to turn over than the first time.
Do you think that this is another starter issue? Or do you have any other suggestions on what else I could troubleshoot prior to taking it into my mechanic?
Thanks!
Jeanette
SPONSORED LINKS
Thursday, May 29th, 2008 AT 10:27 PM
