1993 Other Nissan Models
1993 NISSAN
MAMDOUH
Transmission problem
1993 Other Nissan Models V8 Four Wheel Drive Manual
what is the reasons of defferential damage ?
Nov 10, 2009 at 7:20 AM
  • 31,937 POSTS
Hi there,
Differentials are very sturdy items and normally give you may years of trouble free operation, the most common cause of failure is low oil due to a leak, wrong oil used, contaminated oil usually only with X's that do river crossings and don't check for water ingestion from the breather, incorrect bearing & gear set pre loads and clearances, this is not common but can be the case if re built by a unqualified person that dose not understand the importance of the correct set up procedure, and of course just plain wear and tear,i hope this answerers your question.
Mark (mhpautos)
Nov 10, 2009 at 7:34 AM
