1991 Other Nissan Models cooling problem
1991 NISSAN
123,000 MILES • 4 CYL • FWD • AUTOMATIC
DUTCH28
I have a 1991 nissan stanza, and I have antifreeze coming out of my tail pipe. the return hose into the top of the radiator is cold and empty while running. When you turn the heater on in the car, the temp jumps from normal to very hot(in the red). Could this be a water pump failure?
Dec 25, 2007 at 5:56 PM
BLACKOP555
  • 10,386 POSTS
you say it is coming out of the tail pipe? the only way for antifreeze to get in with the engine cylinders is through a bad headgasket and a bad intake manifold gasket if it is a wet type manifold.
Dec 25, 2007 at 8:41 PM
DUTCH28
yes I think its a wet type, but there are two lines that run into the y-pipe, the first is on the y-pipe its self and goes to the E.G.R. valve and the second goes to a little valve? underneath a small black plastic tank which is bolted to a fuse rail. We can see the water slowly leaking out of the first mentioned line or hose.
Dec 25, 2007 at 11:41 PM
BLACKOP555
  • 10,386 POSTS
is there any possible way you could get a picture of what you are describing?
Dec 26, 2007 at 8:34 AM
DUTCH28
yes if you go to photobucket.com and in the middle of the page you will see a search bar with the images icon highlighted and in the search box type, jcmx515, thats my user name and hit enter. It will then say that no maches were found and ask you if you want to view jcmx's album. there you will find all the pictures I have downloaded there for the car at the top. Jesse
Dec 26, 2007 at 3:23 PM
