1990 Other Nissan Models rad fan not turning on when hot
1990 NISSAN
FIREFOX16
Engine Cooling problem
1990 Other Nissan Models Two Wheel Drive Automatic 195000 miles
hi, my rad fan doesnt want to turn on when its hot.
but its working. i wonder what the problem is.
also, it doesnt want to idle when its in drive gear
why is that?
Feb 25, 2008 at 5:57 AM
Could be the temperature switch/fan relay-for the idle problem-check the auxilliary air control valve and throttle switch/throttle position sensor.
Feb 25, 2008 at 6:01 AM
FIREFOX16
i remove the relay and hard wired it and the fans worked,
what would the problem be now? is it the censor?
how do u check the censor for the fan?
Feb 25, 2008 at 6:06 AM
Measure its resistances hot and cold-if okay you have a wire problem to the computer it depends how its wired into the system
Feb 25, 2008 at 9:20 AM
