1990 Other Nissan Models Could it be the oil?
1990 NISSAN
156,000 MILES • 4 CYL • FWD • AUTOMATIC
IAMSAMUEL23
This morning I checked the oil in my 1990 Nissan Stanza, and discovered that it was critically low. I went to Wal-Mart were I purchased two quarts of 10w40 and proceeded to pour it in. Before I could leave the parking lot the car began to sputter as and then shut off. After work I returned to the parking lot and tried to start the engine but it wouldn't start. Any suggestions on a possible cause and solution to my problem would be greatly appreciated.
Nov 19, 2008 at 11:14 AM
  • 75,988 POSTS
Car w/n start-do below to determine if its fuel or spark problem.
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it .
Nov 21, 2008 at 8:36 AM
